TwinTurbo.NET: Nissan 300ZX forum - heat wraps have their own problems...
wilkendw
on December 20, 2005 at 12:14 PM
you can try heatwrapping them (n/m)
posted by ZEngineer
on December 20, 2005 at 10:04 AM
decided not to install on a set of headers when I discovered they voided the manufacturers warrantee... I'd guess you may damage the dp's with wrap.
Megan downpipe/test pipe resonance
Quick_Z
09:24:14 12/20/05
Change your exhaust. Problem solved. (n/m)
Kenny
09:36:27 12/20/05
I changed TO this setup because performance is good --->
Quick_Z
09:43:19 12/20/05
Re: I changed TO this setup because performance is good --->
NismoZ (Louisville)
09:47:57 12/20/05
How do you plan on fixing it without replacing something?
Kenny
09:55:48 12/20/05
He could just keep the revs under 3k. (n/m)
SactoTodd
10:02:30 12/20/05
Or squish some bananas into his ears. (n/m)
Kenny
10:05:32 12/20/05
*thumbs up* Best solution offered so far... (n/m)
Dave N
10:16:55 12/20/05
Now that is a good suggestion. (n/m)
Quick_Z
10:06:18 12/20/05
I would be willing to replace the dp/test pipe with ->
Quick_Z
10:05:21 12/20/05
Exhaust resonance at 3kRPM and TPs is common, in my
Scotts94z32
09:50:16 12/20/05
2nd. stillen is known for this. (n/m)
AntiHero
13:13:01 12/20/05
ZEngineer
10:04:02 12/20/05
2nd. Wrap the downpipes and testpipes both.
cherry
11:58:59 12/20/05
heat wraps have their own problems... -
wilkendw
12:14:40 12/20/05
I wouldn't wrap aluminized, but stainless holds up fine. (n/m)
cherry
12:39:32 12/20/05
megan is crap, trash that ebay junk and get a quality set (n/m)
Southern-Z (Little Rock)
10:56:37 12/20/05
What do you propose?Dp and test pipes,or just test pipes? (n/m)
Quick_Z
10:58:45 12/20/05
keep both, just get a better quality design, better bends
11:09:55 12/20/05
Thanks, I thought they were low quality before buying,asked
Quick_Z
11:22:15 12/20/05
Megan's are fine. Just not the "best".
Woody75 (Denver)
11:30:20 12/20/05
hmmm. looks like you run the greg D's too (n/m)
11:40:19 12/20/05
hmmm. Megan doesn't make a 5 bolt DP (n/m)
aliaZ
11:41:31 12/20/05
I run the Megan DP & TP w/ Greg's cat-back
chenc544
13:27:13 12/20/05
2nd (n/m)
aliaZ
11:42:06 12/20/05
Megan is not the cause of his resonance
aliaZ
11:47:39 12/20/05
whatever toots your whistle man, Is it fair to say.....
12:22:24 12/20/05
nope
aliaZ
13:00:04 12/20/05
if anything, that will make the sound louder.
AntiHero
12:48:43 12/20/05
i too have resonance
Adam (NoVA)
11:14:16 12/20/05
resonators are effective at removing raspiness (n/m)
aliaZ
11:44:50 12/20/05
No rasp=why I love my HKS exhaust:)
2960cc of fury (Houston)
13:22:33 12/20/05
pretty sure you have a resonated X pipe.
Adam (NoVA)
09:11:35 12/21/05
